add protecction to a fb or function
VICTORSJG
2018-06-07
2019-06-11
  • VICTORSJG - 2018-06-07
    Hi, how can i add a protection to a fb or function to hide the programm?
    thanks
  • Anonymous - 2018-06-08
    Are you trying to hide the internal code, hide the whole POU, hide the POU from the SmartCoding display, or other?
  • VICTORSJG - 2018-06-08
    I want to add a similar know how as tia portal or similar programming software, to avoid see the internal code.
  • Anonymous - 2018-06-13
    Put your function or function block in a library, create a compiled library and then your source code is not visible when somebody uses your compiled library. Be sure to keep a copy of the original library, so that you can make changes.
  • VICTORSJG - 2019-06-11
