I would like to set by Python script the PLC setting "Always update variables" to "Enabled 2 (always in bus cycle task)". Is there a way?
In the attachment a screenshot of the UI equivalent.
Thanks in advance.
Best Regards, Daniele
Hi Daniele.
danielesdei hat geschrieben: I would like to set by Python script the PLC setting "Always update variables" to "Enabled 2 (always in bus cycle task)". Is there a way?
CDS-53974
proj = projects.primary found = proj.find('Device', True) if not found: Β Β raise Exception('No device found') dev = found[0] driverinfo = dev.driver_info if not driverinfo: Β Β raise Exception('No driver info present') driverinfo.always_update_variables = AlwaysUpdateVariablesMode.AlwaysInBusCycle
BR Martin
Thanks in advance.
Best Regards,
Daniele
Hi Daniele.
CDS-53974
Martin
