I have the following code:
FUNCTION_BLOCK B VAR idA : INT; idB : INT; END_VAR METHOD FB_Init: BOOL VAR_INPUT bInitRetains: BOOL; // TRUE: the retain variables are initialized (reset warm / reset cold) bInCopyCode: BOOL; // TRUE: the instance will be copied to the copy code afterward (online change) idA : INT; idB : INT; END_VAR // B's FB_init: THIS^.idA := idA; THIS^.idB := idB; FUNCTION_BLOCK A VAR idA : INT; arrB : ARRAY[0..1] OF B[ (idA, 0), (idA, 1) ]; i : INT; END_VAR METHOD FB_Init: BOOL VAR_INPUT bInitRetains: BOOL; // TRUE: the retain variables are initialized (reset warm / reset cold) bInCopyCode: BOOL; // TRUE: the instance will be copied to the copy code afterward (online change) idA : INT; END_VAR // A's FB_init THIS^.idA := idA; PROGRAM PLC_PRG VAR arrA : ARRAY [0..1] OF A[ (0), (1), ]; i : INT; END_VAR
When running the program I would expect A[1].B[1] to have idA and idB to be 1. But idA is always 0.
How do solve this, without using an Init function that runs on the first cycle?
Talk.ru: 1
Related
Talk.ru: 1
Last edit: maoravni 2021-04-22
