Enumeration with 'strict' attribute
swtroelofs
2016-08-02
2016-09-02
  • swtroelofs - 2016-08-02
    Hi everybody,
    I declare the following enumeration:
    {attribute 'strict'}
    TYPE myEnum :
    Β  Β red, yellow, green
    END_TYPE
    Does anybode know the exact function of the Strict attribute?
    And why does this code not compile:
    PROGRAM myPOU
    Β  Β x:BOOL;
    Β  Β e:myEnum;
    e := SEL(x, myEnum.green, myEnum.red);
    I get this error:
    C0358: 'SEL(x, myEnum.green, myEnum.red)' is not a valid value for strict ENUM type 'myEnum'
    When I remove the 'strict' attribute, the code compiles normally.
    Any ideas? Thanks!
  • rickj - 2016-08-03
    You could try using the instance name
    Zitat:
    e := SEL(x, e.green, e.red);
  • Mikado - 2016-08-24
    Bump
    Was does {attribute 'strict'} do and can it be used outisde enums?
  • TimvH
    TimvH - 2016-09-02
    See the CODESYS Help:
    NOTICE!
    As of CODESYS V3.5 SP7, each enumeration that you add to a project receives the 'strict' attribute automatically in the line above the TYPE declaration. For compiler versions >=3.5.7.0 , this causes compile errors in the following cases:
    Arithmetic operation with variables of the enumeration type
    Assignment of a constant value to a variable of the enumeration type, in which the constant does not correspond to an enumeration value
    Assignment of a non-constant value to a variable of the enumeration type, in which the non-constant has another data type than the enumeration type
    The attribute can also be added explicitly or removed.
    Syntax: {attribute 'strict'}
