In the CODESYS IDE I have several symbols defined and I have IEC Symbol Publishing installed. On the IEC Symbol Publishing window and under the IEC Symbols Editor tab, I have dragged symbols from the tree on the left to the grid on the right. All this works fine. Now I want to remove one of the symbols from the grid on the right and I cannot see any way to do this. How can I remove a symbol from the grid on the right once I've added it?
Right now when I make a change to one of the tags in my code, I have to completely remove the IEC Symbol Publishing object from the tree view and re-add it. Then I have to completely re-add every symbol to the grid view by dragging them over. This can be a lot. Surely, this is not the intended behavior. Can anyone tell me how this is supposed to work?
Hi, I've never used Communication Manager, but I tried it and I saw that I can drag tags from left to right. If I click on a line on the right, it turns light blue. By pressing the DEL or CANC key (It depends on your keyboard language) I can delete the line
gatto, That works. Thanks. Typically I use my mouse more than my keyboard. That's why I was looking for a delete option from the right-click context menu or a delete button on a toolbar at the top. It never occured to me to use the keyboard. It might be a little more user friendly if they allowed a mouse wise ability to remove a line from the grid as well as the DEL key. Just a suggestion. Thanks for your help.
Hi, can you post some screenshots?
here is a screenshot. I dragged Device.Application > GVL_Sched > Requests to the grid on the right, but I cannot remove it from the grid.
