As you might have learned with Algebra, functions don't preserve memory and are state independant. They are purely input dependant. This means that the output of a function is always directly related to the inputs and do not contain any memory states.
example:
f(x) = sin(t)
To use memory states you should use a FUNCTION BLOCK instead of a FUNCTION. Then youre code wil work.
Last edit: hermsen 2021-08-19
Effectively it's work much better with FB. Sorry for that.
For naming , I would change it was more for trial purpose and understand how does work. Now I can do it in proper way.
Thank You again.
Regards
Hello to all,
I would need some help.
Instead of using PRG, I've tried to use a function
I've fews rotary switchs that I'm trying to count when values change.
So instead of trying to create multiple PRG, the idea was to use a fuction for.
And unfortunaly it doesn't react.
someone has any idea.~~~
code
FUNCTION Rotary_switch_selection : USINT
VAR_INPUT
F_P1pot :USINT;
F_P1pot_TON1:TON;
F_P1pot_TON2:TON;
F_P1pot_RTRIG:R_TRIG;
F_FunctionCTUD: CTUD;
F_Ppotbis :USINT;
F_Functionup:BOOL;
F_Functiondown:BOOL;
F_VAL2:BOOL;
F_PV1:WORD;
then in my "main" to call
PROGRAM Main
P1value:USINT;
P1value:=Rotary_switch_selection( F_P1pot:=GVL.P1pot );
GVL.P1pot => is my Potentiometer value.
thank you for your help.
sorry I miss some parts of the code!!
codeFUNCTION Rotary_switch_selection : USINT
VAR_INPUT
F_P1pot :USINT;
F_P1pot_TON1:TON;
F_P1pot_TON2:TON;
F_Ppotbis :USINT;
F_Functionup:BOOL;
F_VAL2:BOOL;
F_PV1:WORD;
code of the function:
F_P1pot_TON1(IN:= NOT F_P1pot_TON2.Q , pt:=T#0.2S);
F_P1pot_TON2(IN:= F_P1pot_TON1.Q , pt:=T#0.2S);
F_P1pot_RTRIG(CLK:=F_P1pot_TON1.Q , Q=> );
IF F_P1pot_RTRIG.Q THEN
F_Ppotbis:=F_P1pot;
IF F_P1pot > F_Ppotbis THEN
F_Functionup:=TRUE;
F_Functiondown:=FALSE;
ELSIF F_P1pot < F_Ppotbis THEN
F_Functionup:=FALSE;
F_Functiondown:=TRUE;
ELSE
hi,
example:
f(x) = sin(t)
tip
F_P1pot_TON1:TON; -> try to name it according to what the TON represents, not what it is. Here your var represents some p1potWaitTime or so
Thank You.
Thank You again.
Regards
