I could manage to write a script that creates an online application, log-in, and start the PLC as shown in the below function code.
def plc_start():
onlineapp = online.create_online_application(None)
onlineapp.login(0,True)
plc_login()
onlineapp.start()
print("started")
To stop the plc while staying logged in, I need to use the <onlineapp>.stop(). The problem is that I'm not able to keep the declaration of the <onlineapp> to a next run of the script. So, I want to "ask the scriptEngine what online application is existing now"? How could I program for this question knowing that there is nothing as <active_online_application> in the scriptEngine help?</active_online_application></onlineapp></onlineapp>
BR,
Halim
Halim hat geschrieben:
ScriptEngine has no need to remember which online application exists because it is not necessary. Just create a new online application and check if it is logged in. If not, login and stop the running app.
Martin
Hi.
def plc_start():
plc_login()
onlineapp.start()
print("started")
BR,
Halim
Hi Halim.
Martin
