Unfortunately, I don't get the button that says "Download missing libraries" so I cannot automatically download it. I attached a screenshot.
Also, I don't know where to manually download the library. I tried searching "syssem 3.5.16" on Google and in the Codesys store, but could not find anything. The closest I found was the link in my original post, but that is a link to the documentation of the library on the Codesys Help website, not the actual library itself.
You don't need to download the library, probably. Push the add a library button and do a search for SysSem. If you don't get anything, on the bottom left push the 'Advanced...' button and search again. On my own system to get SysSem to pop up I had to do the advanced search.
I tried that as well, but only an older version, SysSem 3.5.5.0, showed up. I added that library and tried to compile, but unfortunately still get the error that I need SysSem 3.5.16.0. See attached screenshots.
Which version of the Codesys IDE are you using? You might need to download the most recent 3.5.16 version. If that's what you have I can send you a copy of the library.
Ah yeah. Unfortunately library version numbers don't necessarily track IDE version so it looks like there was a big jump from 3.5.5 to 3.5.16 for that library.
1 thing to check is the library manager in both the 'Devices' tab as well as the 'POUs' tab. You might have a download missing libraries button there. At this moment it seems odd to me that it's complaining about a missing library but not including that button. But I haven't had my first coffee yet either.
Last edit: Morberis 2021-01-18
I just checked the Library Manager in 'Devices', but that manager isn't showing the "download missing libraries" button either. It sounds like I need to download and install SP16...
Hi, I am getting an error that says "Library SysSem, 3.5.16.0 has not been added to the Library Manager." I attached a screenshot.
Does anyone know where I can download this library?
It looks like this is the library documentation on the Codesys Help website:
https://help.codesys.com/webapp/idx-SysSem-lib;product=SysSem;version=3.5.16.0
Thanks,
Jefferson
Have you tried the download missing libraries button in the library manager? Or if none are missing, manually adding the library?
Last edit: Morberis 2021-01-17
Hi, Morberis,
Any help would be appreciated.
Thanks,
Jefferson
Last edit: jeffersonhui 2021-01-17
Bah double post
Hi, Morberis,
Thanks,
Jefferson
I'm using SP14 actually. That would make sense...
Here's a copy from my IDE. Unzip it and place in
C:\ProgramData\CODESYS\Managed Libraries\System
Though you might want to still grab the new Codesys IDE.
