Iβm using an IFM ecomatBasic CR413S controller and having trouble connecting it to CODESYS 3.5. I have CODESYS SP18 installed, as recommended in the manual, and Iβve tried different patches. Iβve also installed all the packages provided on the IFM website for this controller.
I can successfully connect to the ecomatBasic template, but Iβm unable to connect when using the CR413S-specific template that includes all the inputs and outputs.
Has anyone encountered this issue or knows a solution?
Best regards,
Jan
Could you please send an print of your ethernet adapter info?
Ip addr
Subnet Mask
Default Gateway
Also, check if the gateway service is active in your windows.
Win+R > services.msc >
Look in the list CODESYS Control Win V3 x64 Gateway OR CODESYS Gateway V3
Hook up the M12 code D into the ETH port, supply the controller, it should apperars to you.
Make sure when you try to connect with the controller, the target of your project has to match with the controller. Otherwise, click on the device in the devices tree > Communications Settings tab > Device > Options > And disable "Filter Network Scans by Target ID".
Good luck.
Hi everyone,
Best regards,
Jan
So you don't see the device when scanning for devices?
Im not familiar with that device. how dose it connect? serial/ethernet?
Ip addr
Subnet Mask
Default Gateway
Good luck.
