Is it possible to use the Test manager with Simulation mode instead of downloading to an actual runtime? I get the error:
Zitat:
Variable not found, the application must be compiled and online for this operation
when attempting to run unit tests with the device in simulation mode. The tests work fine when using a real runtime but in my setup that requires actual, physical hardware. I know I can Update the device in the project to use Control Win but my project won't compile without errors that need to be resolved then
dFx hat geschrieben:
when you run simulation mode, you have to login into the simulated plc as you would in a real plc to be online.
Yes, and Test Manager does this with the generated test application. I can see that it is online (and in Simulation) with the application and that it is in Running mode but the test fails with "Variable not found, the application must be compiled and online for this operation" in the report.
I am running into the same issue and was wondering if you found a solution?
