Hello team
I'm using the Serial Com Library from the Codesys Store. It appears as V3.5.7.0
My target uses 3.5.10.10
Should this be ok?
The reason I ask is that I'm finding the Runtime 'fragile', and it appears to be connected to this library.
Can someone confirm please?
Paul
ph0010421 hat geschrieben:
Hello team
Should this be ok?
Paul
I'm running 3.5.10.40, and I'm seeing the same Serial library. What this means is that it's the latest build (i.e. most stable). Maybe you can elaborate more on the fragility aspects. I've done some simple testing, and it works great so far.
2017-06-20
Hello nothinrandom
Thanks for the reply. I'm encouraged that you are having no problems.
The FBs do work, but I'm seeing the rt crash during an online edit for example.
If I don't 'use' any of the FBs then I'm ok.
I do repeatedly execute the COM.Read (toggle the xExecute with its own xDone flag) and wonder if 'something' can't keep up.
As an aside, the szSize output seems to have a value in when it shouldn't, but that's for another time.
Paul
Hello team
Should this be ok?
Paul
Hello nothinrandom
Paul
