TCP/IP Client and connection handle issue
Robiston
2012-07-10
2012-12-20
  • Robiston - 2012-07-10
    I am currently working on a TCP/IP implementation in CoDeSys V3, whereas the IEC61131-3 program has to be the server. For whatever reason, it is not possible to receive any data from the point of view of TCP client, even though a working connection could be established.
    I am using the NetBaseServices.
    Please refer to the following code:
    ---HEADER---
    PROGRAM TCP_Client
       bFirst: BOOL := TRUE;
       My_Data: ARRAY[0..4] OF BYTE := [0,1,2,3,4];
       NBS_IP_Adress : NBS.IP_ADDR;
       TCPClient : NBS.TCP_Client;
       TCPClient_xDone : BOOL;
       TCPClient_xBusy : BOOL;
       TCPClient_eError : NBS.ERROR;
       TCPClient_xActive : BOOL;
       TCPClient_hConn : NBS.CAA.HANDLE;
       TCPServer : NBS.TCP_Server;
       TCPServer_xDone : BOOL;
       TCPServer_xBusy : BOOL;
       TCPServer_eError : NBS.ERROR;
       TCPServer_xError : BOOL;
       TCPServer_hServer : NBS.CAA.HANDLE;
       TCPConnection : NBS.TCP_Connection;
       TCPConnection_xDone: BOOL;
       TCPConnection_eError : NBS.ERROR;
       TCPConnection_xActive : BOOL;
       TCPWrite : NBS.TCP_Write;
       TCPWrite_xDone : BOOL;
       TCPWrite_xBusy : BOOL;
       TCPWrite_eError : NBS.ERROR;
       TCPWrite_xError : BOOL;
    ---PROGRAM---
    IF bFirst THEN
       bFirst := FALSE;
       // CoDeSys Automation Alliance (CAA) Interfaces - NetBaseServices (NBS)
       NBS_IP_Adress.sAddr := '192.168.178.39';
       TCPServer(
          xEnable := TRUE,
          ipAddr := NBS_IP_Adress,
          uiPort := 61002,
          xDone => TCPServer_xDone,
          xBusy => TCPServer_xBusy,
          eError => TCPServer_eError,
          xError => TCPServer_xError,
    My_Data[0] := My_Data[0]+1;
    My_Data[1] := My_Data[1]+1;
    My_Data[2] := My_Data[2]+1;
    My_Data[3] := My_Data[3]+1;
    My_Data[4] := My_Data[4]+1;
    TCPConnection(
       xEnable := TRUE,
       hServer := TCPServer.hServer,
       xDone => TCPConnection_xDone,
       eError => TCPConnection_eError,
       xActive => TCPConnection_xActive
    IF TCPConnection.xDone THEN
       TCPWrite(
          xExecute := TRUE,
          hConnection := TCPConnection.hConnection,
          pData := ADR(My_Data),
          szSize := SIZEOF(My_Data),
          xDone => TCPWrite_xDone,
          xBusy => TCPWrite_xBusy,
          xError => TCPWrite_xError,
          eError => TCPWrite_eError
    Do you have an idea what is wrong with my implementation?
    Thanks in advance for your kind support.
    Regards,
    Robert
    Related
    Talk.ru: 1
    Talk.ru: 2
    Talk.ru: 3
  • TimvH
    TimvH - 2012-07-11
    I'm not 100% sure, but here some things that might help:
    - Always call the TCPServer FB (not just the first scan) with xEnable TRUE.
    - Enable the TCPConnection when the TCPServer handle is not invalid or 0.
    - Execute the TCPWrite FB when the TCPConnection is Active (not when it is done)
    - An Execute input of the FB is a trigger to start it, therefore the data is only send once in your application. Replace the TRUE for a puls generator or something similar.
  • Robiston - 2012-07-11
    Hey TimvH,
    "Always call the TCPServer FB (not just the first scan) with xEnable TRUE" helped me out!
    Thank you for your help!
  • jzhvymetal - 2012-07-29
    I would recommend using the OsCat Network Library it has been tested and validated. You can use the IP_CONTROL FB's to implement you own TCP SERVER.
    You have to be signed in to download. This has been updated for CoDeSys V3.
    http://www.oscat.de/community/index.php ... 784.0.html m
  • SkyRuwen - 2012-12-20
    Hello Robinston,
    I tried your code (and I ran TCPServer always, as it was recommended, not only in the first run), but in my TCPWrite FB, I get "Invalid Handle", even if I try the other recommended issues, posted by TimvH.
    Did you only deleted the IF bfirst THEN-Loop - or did you some other changes in your code until it worked?
    Thanks in advance for your kind help.
    Best Regards
    Ruwen
