Hi all, I am returning to using PLC's after not having used them for some 20 odd years. My have things changed!
I'm new to CodeSys and am writing a simple program in ST to learn the IDE and test my old skills.
Clearly they're not very good.
I am try to divide two declared signed integer variables and store in a REAL variable i.e.140 / 16
The answer should be 8.75 but when I run the program in simulation the real variable shows only the 8 with no decimal place or anything thereafter.
Can anyone help with what am I doing wrong please?
Embarrassingly I just realised the same just before you posted your kind reply!
Its been a while and sometime it's a case of "If you don't use it.....you lose it!"
Hopefully with more practice some of it will come back.
Newbie Question!
Hi Biggles!
To get a REAL result, you have to do the calculation in REAL. So just convert the SINTs into REAL and do the calculation then:
rResult: REAL;
siInput1: SINT;
siInput2: SINT;
rResult:= SINT_TO_REAL(siInput1) / SINT_TO_REAL(siInput2);
That should work!
Alfred
Thanks Alfred!
