I have created a library with both code and visualizations to be used in multiple other projects. After I update the library version into the library repository, I have much difficulty updating the version into the main project.
I can always update the library version in the Library Manager just fine.
My issue, is sometimes Codesys will freeze when opening the visualization that uses the library visualizations. Sometimes it opens, but freezes when I try to access the library visualizations from the Visualization Toolbox.
I try letting Codesys run for upwards of 4+ hours and it is stuck in this state. On very rare cases I have no issues and can continue with my work. I haven't found a consistent reason or work around. Has anyone else had this happen?
Last edit: tyleretn 2025-02-27
