command line options --skipunlicencedplugins
etamgul
2015-08-03
2015-09-08
  • etamgul - 2015-08-03
    I have a "Test Manager" plugin installed which requires a USB licence dongle and sometimes I have to remove the USB key,
    but still I want to use some codesys.exe with scripts (which do not require this plugin).
    To solve this problem I found this "--skipunlicencedplugins" exe parameter but seems that it is not working (v3.5 SP6).
    Are there any additional parameters required? Or is this not supported (just documented) yet?
  • mkeller - 2015-08-17
    Hi.
    You have a typo in your parameter. The correct one is "--skipunlicensedplugins".
    Martin
  • etamgul - 2015-09-08
    Thank you I will check it out, but if that is valid than its a documentation issue.
    Latest help gave me the hint that I should use this parameter:
    Example
    CODESYS.exe --skipunlicencedplugins
  • mkeller - 2015-09-08
    Hi etamgul.
    You are right. It's an error in the documentation. I told my colleague and he fixed it. In the next release of CODESYS the help will contain the correct notation.
    Martin
