Using exadecimal variables in GV and PRG
micelan
2016-05-17
2016-05-19
  • micelan - 2016-05-17
    Good afternoon,
    I need to call into 'Global variables' the variables defined into 'service data object' (in the picture1).
    [img]Codesys.png[/img]
    How can I define them? And, how can I see the address I have to use?
    Sonda1 AT %IW??? :WORD;
    Thank you
    IMG: Codesys.png
  • learnetk - 2016-05-17
    normally you would need to use the Function block SDO_Read in the CIA405 library. The library is added along with
    the can device.
    IMG: can.PNG
  • micelan - 2016-05-19
    Thank you for the response.
    So basically I have to put inside my PLC_PRG a function that can read that address correct?
    Something as:
    test:= := CIA405.SDO_READ4(x,x,x,x,x,x,x,x,x,x,x,x);
    Correct?
