epinikion - 2020-10-23
Hi all,
I wrote a FB to read the content of specific text files. It chooses a text file depending of the input "bRfidNo", for instance: bRfidNo at 1 would open 1.txt and save the contents on a local array in the PLC. It uses the "File Access" library and its function Blocks.
Thing is, when I use my FB on PLC_PRG and choose manually bRfidNo it works fine. But I wanted too by Startup of the PLC have it read every text file and add all its contents on the local Array. I wrote a Startup subprogramm which is basically a loop of my Read-FB until he readed everything, but it remains stuck on Case 10 of the FB.
Here's the Code of the FB. The "fbRead(xRead) remains stuck on true, so I'm suspecting I'm starting the input wrong on my Startup-program maybe?
fopen.xDone doesn't seem to turn on when I call the FB inside another PRG either, despite that I get no fopen.xError.
FUNCTION_BLOCK FB_RackRead
///Dieser FB liest derzeitige Daten aus der Buffer-Textdatei.
VAR CONSTANT
VAR_INPUT
    xRead:                          BOOL;
    bRfidNo:                        BYTE;
VAR_OUTPUT
    xReadDone:                      BOOL;
    xBusy:                          BOOL;
    xError:                         BOOL;
    eError:                         File.ERROR;
VAR_IN_OUT
    sFilePath:                      STRING;// Pfad bzw. Dateiname
    //Schritt des Ablaufs
    uiStep:                         UDINT:=0;
    //Backup Data processing
    iCounter1:                      INT:=1;
    //File Access
    hFile:                          CAA.HANDLE;
    szFileSize1:                    CAA.SIZE := 0;
    szFileSize2:                    CAA.SIZE := 0;
    fopen:                          FILE.Open;
    fread:                          FILE.Read;
    fclose:                         FILE.Close;
    sFileName:                      CAA.FILENAME;
    sStringToRead:                  STRING(9999);
    sStringToWork:                  STRING(9999);
    iStringFIND:                    INT;
    sStringMID:                     STRING:='';
    uReadIndex:                     UINT:=1;
    //Control characters
    CRLF:                           STRING(5):=';$R$N'; //Line-Break
VAR_IN_OUT
    saaList:                ARRAY[1..16] OF ARRAY [1..36] OF STRING;
CASE uiStep OF
        (*warte auf Trigger*)
    0:  IF xRead AND bRfidNo >= 1 AND bRfidNo <= 16 THEN
            xRead:=FALSE;
            xBusy:=TRUE;
            xReadDone:=FALSE;
            uiStep:=10;
            iCounter1:=1;
            sFilePath:=CONCAT('Local_Buffer\',INT_TO_STRING(bRfidNo));      //Open the buffer.txt of the selected Rack
            sFilePath:=CONCAT(sFilePath,'.txt');
    10: (* create or open my log-file for the HEADER*)
        fopen.sFileName:=sFilePath;
        fopen.eFileMode:=File.MODE.MREAD;
        fopen.xExclusive:=TRUE;
        fopen( xExecute:=TRUE);
        IF fopen.xDone THEN
            hFile:=fopen.hFile;
            uReadIndex:=0;
            uiStep:=20;
        IF fopen.xError THEN
            (* error handling*)
            xError:=TRUE;
            eError:=fopen.eError;
    20: (* read log data to file*)
        fread.hFile:=hFile;
        fread.pBuffer:=ADR(sStringToRead);
        fread.szBuffer:=SIZEOF(sStringToRead);
        fread.udiTimeOut:=100000;   //Timeout
        fread( xExecute:=TRUE);
        IF fread.xDone THEN
            fread(xExecute := FALSE);
            sStringToWork:=sStringToRead;
            szFileSize2:=fread.szSize;
            uiStep:=30;
        IF fread.xError THEN
                //Error
                xBusy:=FALSE;
                xRead:=FALSE;
                uiStep:=40;
    30:  (* adapt text data to arrays *)
        FOR iCounter1 := 1 TO 36 BY 1 DO
            iStringFIND := stu.StrFindA(ADR(sStringToRead),ADR(CRLF),1);                            //Find the first line break (;$R$N)
            StrMidA(        //Extract the first Panel-String from the whole readed text
                pst:= ADR(sStringToRead),
                uiInputBufferSize:= SIZEOF(sStringToRead),
                iLength:= iStringFIND - 1,
                iPosition:= 1,
                pstResult:= ADR(sStringMID),
                uiResultBufferSize:= SIZEOF(sStringMID));
            saaList[bRfidNo][iCounter1] := sStringMID;                                              //Add the Panel to the local Rack Array
            StrDeleteA(pby:= ADR(sStringToRead), iLength:= (iStringFIND + 2), iPosition:= 1);
        END_FOR
        uiStep:= 40;
    40:  (* close log file *)
        fclose.hFile:=hFile;
        fclose( xExecute:=TRUE);
        IF fclose.xDone THEN
            fopen( xExecute:=FALSE);
            fread( xExecute:=FALSE);
            fclose( xExecute:=FALSE);
            xReadDone:=TRUE;
//          xRead:=TRUE;
            xBusy:=FALSE;
            //uiStep:=50;
            iCounter1:=1;
        //  uiStep:=0;
        IF fclose.xError THEN
            //Error
            xBusy:=FALSE;
            xRead:=FALSE;
            uiStep:=0;
END_CASE
And here the Startup-program (I tried too with FORs, Ifs etc, no difference)
IF xStart THEN
    xBusy:=TRUE;
    xStart:=FALSE;
    WHILE bRackNo<=16 DO
        fbRead(xRead:=TRUE,bRfidNo:=bRackNo,saaList:=saaList);
        IF FbRead.xReadDone THEN
        bRackNo:=bRackNo+1;
    END_WHILE
    saaRack:=saaList;
    xBusy:=FALSE;
    xDone:=TRUE;
Last edit: epinikion 2020-10-23
