Hi all,
I am trying to utilize the ARRAY_SDV standard deviation function, part of the Math group in the OSCAT library downloaded from the CODESYS store. My Codesys version is 3.5.19.10. When I add the OSCAT to my Library, it shows a subset of the library (Standard) as fully installed and signed (see pic). However, the Math functions are not in this Standard group. The Math functions I need can be viewed as source code in the full OSCAT_BASIC, though this the symbol next to this library suggests it is source only and not fully installed.
When I try to declare an instance of the ARRAY_SDV function in a program, it is not known. I have tried reinstalling and Building . . .
Hi all,
Any help would be greatly appreciated.
Jeff
Try to declare it like this:
Thank you seoerr for your suggestion. When I implement that line, I get this error:
[ERROR] 'OSCAT_BASIC.ARRAY_SDV' is of type FUNCTION and cannot be instantiated**
Any other thoughts about instantiating these sections of the library which seem to be provided as source only?
Last edit: jdjennings1962 2024-01-16
