codesys mqtt publish serialization
amy123
2024-02-16
2024-06-05
  • amy123 - 2024-02-16
    I am using the CODESYS IIoT Libraries SL MQTT Publish. Does this publish block only support publishing STRINGS as a readable format?
    I can publish ENUM, STRUCT, BOOL; however, MQTT Explorer will only display strings. When I use Wireshark, I can see that it is publishing something, but it looks to be publishing a serialized version which is a bunch of 0s or random text.
    If so, is there any way to deserialize this information back into a readable format? See pictures, where I have a BOOL TRUE that gets published as 001. Then see where I publish a STRUCT and it's an incomprehensible combination of 0s - only the string variable is displayed.
    Or, is it expected that you convert everything to a string before publishing?
    Any help is greatly appreciated! :)
  • mmpl - 2024-03-26
    Did you get any Luck? I am on same boat. Can you please share your latest Snip.
    Thank you
  • Rampage_Rick - 2024-06-05
    pbPayload is a pointer, which it expects to point at a STRING. If you point it at an address holding a different data type, it will just assume those bytes are part of a string and likely trundle along memory until it finds a null byte (0x00) that would normally signify the end of a string
    PublishMessage := BOOL_TO_STRING(boolVariable);
    Last edit: Rampage_Rick 2024-06-05
