cerate and add a submodule for a PN slave
2017-03-03
2017-03-06
  • Anonymous - 2017-03-03
    Originally created by: Steffen_R.
    How can I create a submodule and add it in a plugged in Profinet slave?
    Steffen_R.
  • mkeller - 2017-03-03
    Hi Steffen_R.
    Steffen_R. hat geschrieben:
    I'm not sure what you mean with "create a submodule".
    If you want to add a module below your Profinet slave you just have to use the method but also specify the module ID parameter.
    There are some devices which have so called slots. For slots you use the method of the slot object instead of of the parent device object.
    Martin
  • Anonymous - 2017-03-06
    Hi Martin,
    I've got it so far. Thank you for that. But the problem I mentioned i my other thread still exists. After adding everything i go online und run the application. But there are still connection(?) problems....
    Then i have to stop and logout, open the et200s treeobject, go online again and it runs.
    I recognized that before i do that, the hostparameter id=1025 Name=slaveoptions is missing...
    I tried it with disable and enable the device but nothing works...
    Is there something i can do??
    Thank you
    Steffen
    IMG: fehler3.PNG
    IMG: geht.PNG
  • mkeller - 2017-03-06
    Hi Steffen.
    That has nothing to do with the topic so please don't mix them.
    Martin
    I'm sorry
