I'd like to launch the EtherCAT bus on the WinV3 RTS via normal Ethernet on my notebook.
What i have done for it:
0) read documentation
1) downloaded and installed winPcap
2) added entry to the .cfg file - Component.2=SysEthernet
3) launched WinV3 (stopped it before)
and i got the log:
1315393824: Cmp=CM, Class=1, Error=0, Info=34, pszInfo= CoDeSys Control ready
1315393824: Cmp=SysEthernet, Class=4, Error=0, Info=0, pszInfo=**** DrvEtherCat:
error retrieving/comparing the MAC address of the adapter!
Β Did not find Network Adapter with Mac Adr 00:00:00:00:00:00!
1315393824: Cmp=IoDrvEtherCAT, Class=1, Error=0, Info=0, pszInfo= Networkadapter
Β could not be opened
1315393824: Cmp=IoDrvEtherCAT, Class=1, Error=0, Info=0, pszInfo= Error: Prepara
tion was not successfull
1315393825: Cmp=CmpRouter, Class=1, Error=0, Info=1, pszInfo= Setting router <instance>2</instance> address to <address>(0108:0001)</address>
EtherCAT Master doesn't see any slave.
what have i missed?
Thank's
It is advised to use the latest version of CoDeSys (at the moment 3.4.4.0).
Make sure your V3 Control Win is running.
Double click on your device, scan the network and set your Win PLC as active path.
Now go to the EtherCAT adapter and choose the correct MAC ID (it should show at least one).
After you have set this correctly you should be able to find them.
TimvH hat geschrieben:
Thank you very much! the key word was correct MAC ID. i chose not correct one how could't i notice it before? i don't know. i've fixed it and it works now.
But still launching WinV3 gives the same log with full zeros of MAC ID. i don't know it is right or not but it works
thanks!
Hello everybody! Can you help me?
and i got the log:
what have i missed?
Thank's
thanks!
