I Created the module "PersistanceManager"
And generated the software with Composer->Generate
If i build my application I dont have any errors.
But when I try to login to my controller I getting build errors.
How is this possible?
See attachment for error messages.
I am using Codesys v3.5 SP11
In SP11 there is a separate Build>Build command and Build>Generate Code command. The Build>Generate command is not the same as an Composer>Generate command.
And it seems that the stack overflow check is done in the Build>Generate and not the Build>Build part of it.
You could read more about it here and here.
