Hello! I am trying to compare 2 projects via the --compare CLI option. In the docs for the --compare option, it describes the usage as .\CODESYS.exe --compare "project path 1" "project path 2".
I store my projects in WSL2 on my windows machine. Since CODESYS is happy to open those projects via a path like \\wsl.localhost\home\project.project. So, to compare, I use the command .\CODESYS.exe --compare "\\wsl.localhost\home\prog1.project" "\\wsl.localhost\home\prog2.project".
This results in CODESYS just opening the project and starting, not comparing the two projects. No errors are thrown, and I know the paths are correct since I can open both independently in CODESYS, and I can compare them manually through the CODESYS UI.
I have also tried moving my projects to the Windows 11 OS and still have the same issue. CODESYS opens the project and does not actually compare them.
I am using CODESYS profile v3.5 sp20 patch 1.
What is the correct way to compare 2 projects using the --compare CLI option?
--compareCLI option. In the docs for the--compareoption, it describes the usage as.\CODESYS.exe --compare "project path 1" "project path 2".I store my projects in WSL2 on my windows machine. Since CODESYS is happy to open those projects via a path like
\\wsl.localhost\home\project.project. So, to compare, I use the command.\CODESYS.exe --compare "\\wsl.localhost\home\prog1.project" "\\wsl.localhost\home\prog2.project".This results in CODESYS just opening the project and starting, not comparing the two projects. No errors are thrown, and I know the paths are correct since I can open both independently in CODESYS, and I can compare them manually through the CODESYS UI.
--compareCLI option?
