How to use SysFileOpen function?
2011-04-26
2011-05-04
  • Anonymous - 2011-04-26
    Originally created by: 8Strings
    I am new to CoDeSys. I am trying to use the function SysFileOpen to open a file, I saw that on the 2.3 versione the usage was:
    SysFileOpen(´filename´, ´access mode´);
    How does it work on the version 3?
    From the documentation I see:
    SysFileOpen(´filename´, ´access mode´, pointer to an error object);
    I was adding the CmpError Library to my project but doesn´t seem to recognize any of the contained error objects declared in there.
    Thanks,
    8Strings.
  • DaveLuscher - 2011-05-04
    Hi Strings
    Sadly this is a slow forum where I have not got any help in the past. To get the ball rolling here some hints on the SysFileOpen. The third item is a pointer to an error code. e.g.
    rte: RTS_IEC_RESULT; //Error code according to runtime error list
    fh: RTS_IEC_HANDLE; // file handle
    fileName: STRING[63] := '\dir\myfile.bin';
    in code area
    fh := SysFileOpen( fileName, AM_READ, ADR(rte));
    good luck
    DaveLuscher
