When you create a batch file to start a script, it works best if you put it in the common folder of CoDeSys V3. You can also use the following method:
Just create a .bat file and place the following text in this file (modify the path to your script):
rem all options: start /wait CoDeSys.exe --profile="..." --enablescripttracing --noUI --runscript="..." pushd "C:\Program Files (x86)\3S CoDeSys\CoDeSys\Common" start "MyScriptNameAsOption" /wait CoDeSys.exe --profile="CoDeSys V3.4 SP3 Patch 1" --enablescripttracing --runscript="C:\_d\Python\CommandLineStart\importXML.py"
