Multipage menu with locked section
dvincent
2020-10-29
2020-10-30
  • dvincent - 2020-10-29
    I'm creating a multipage visualization IHM and I would like to create a common menu for all of them.
    I don't want to add manually all the button on each webpage.
    Is it possible to create different login access like root / user / free
    thanks
    • Morberis
      Morberis - 2020-10-29
      Totally doable. Add the VisuUserMgmt libraries to your project and you'll find a new tab in your Visualization Manager called 'User Management'.
      After you have the users setup you also have a new item in the visualization elements properties tab called 'Access Rights'. It is there that you specify whether that element is interactable, greyed out, or invisible to each user type.
    Great
    I'm newbie in codesys ,In the library manager I don't see VisuUserMgmt library.
  • dvincent - 2020-10-30
    Ok I've found it , translation problem it is not a lib. 😌😌😌
    thanks
    Now I need how to find a way to make the menu
    I've found, the current Project category is in the toolbox
