Using VAR_STAT in FB
fpin
2018-01-09
2018-01-10
  • fpin - 2018-01-09
    Hi everybody,
    I'm founding some problems with the VAR_STAT in the function block: I don't understand why the variables that I declare in the VAR_STAT field are set to 0 everytime that the function block is called. I tried to not initialized the variables but nothing happens, do I have to set something else?
    I saw that if I use the VAR type I obtain the result that I want but why it should be like this?
  • Anonymous - 2018-01-09
    Originally created by: rickj
    As I understand VAR variables declared in the main FB body are already static. I'm not sure how VAR_STAT is interpreted in the main body, but it probably ends up being something like a class variable, where it's the one and same variable for all instances of the FB. Try incrementing a VAR_STAT variable on the first execution of the block to see if it counts the number of instances.
    I believe that if you use VAR_STAT in a method or a function then you would get the expected behavior.
  • fpin - 2018-01-10
    rickj hat geschrieben:
    Ok, thanks for the answer. I will try to increment a VAR_STAT variable when I will have time to do that test.
