IP adres gateway
2020-10-16
2020-10-24
  • Reinier Geers - 2020-10-16
    I Want to make een VPN connection. So i want to add a gateway. But i cant change Port to IP adres. Why ? Somtimes i can change but now not. Why issnt this stable
  • TimvH
    TimvH - 2020-10-24
    I think you are using this incorrectly.
    Behind IP address is the IP address you can use. By default this is localhost. You can change this.
    Behind Port you can see the default port number that the Gateway will use.
    (probably you thought that below IP address you could enter the IP address, but you should look at the right side of it and change localhost to your desired IP address....)
