Is there a way to install new libraries in CoDeSys V3 from the script engine?
The documentation states that it is possible to add_library to a project, but I cannot find a command to install the libraries so they can be added afterwards.
I am using CoDeSys V3.4 SP3 Patch 1.
Best regards,
Frank Jepsen
kk-electronic a/s
2011-06-07
Currently, this functionality is not available.
But there is a workaround: Pack the library into a project archive, and open that archive using open_archive. This should install all libraries contained in the archive.
This workaround should solve some of the use cases.
Regards,
Markus
I have upgraded to V3.5 Patch 3 now and I can see that more objects has become available.
Could you provide an example using the ILibManager to install a library?
I would like to install e.g. "c:\myfunction.library" into the CoDeSys IDE, so I can add it to other projects.
Regards,
Frank
2012-04-23
Hi, Frank,
Frank Jepsen hat geschrieben:
I stripped one of my internal test scripts a little bit, here's the code. It demonstrates displaying all libraries, creating and deleting library repositories, and installation and uninstallation of libraries.
from__future__importprint_functionimportosforrepoinlibrarymanager.repositories:Â Â print(repo.name,"(",repo.root_folder,", ",repo.editable,")")Â Â forlibinlibrarymanager.get_all_libraries(repo):Â Â Â Â print("Â Â ",lib.displayname)Â Â Â Â print("Â Â Â Â Cats: ",", ".join(map(str,lib.categories)))Â Â Â Â print("Â Â Â Â Deps: ",", ".join(map(str,lib.dependencies)))print("")oldrepocount=len(librarymanager.repositories)print("Trying to create repo")repopath="C:\\Path\\to\\temporary\\dir\\REPO"os.makedirs(repopath)Â Â newrepo=librarymanager.insert_repository(repopath,"Script_Test_Repo")assert(len(librarymanager.repositories)==oldrepocount+1)print("Trying to install library")libpath="C:\\Path\\to\\Testlib.library"installedlib=librarymanager.install_library(libpath,repo,overwrite=True)print("Trying to find library")foundlib,repo=librarymanager.find_library("MSch Test library, 3.4.4.0 (3S Smart Software GmbH)")assert(repo==newrepo,"repo does not match!")assert(foundlib==installedlib,"lib does not match!")print("Uninstalling library")librarymanager.uninstall_library(repo,foundlib)print("Removing repository")librarymanager.remove_repository(newrepo,delete_on_disk=True)assert(notos.path.isdir(repopath),"repo deletion failed")print("script finished.")
Here's a second script which installs all librarie swhich are found in a given directory. Our test department sometimes uses it to install all libraries which were ever released with CoDeSys into a fresh installation (for example, in a Virtual Machine).
\# -*- coding: utf-8 -*.from__future__importprint_functionimportos
\# The directory we want to install libraries from.LIBDIRS=(r"D:\WorkingCopies\LibrariesV3Tags",)
\# Search order (compiled vs. source libraries)EXTENSIONS=(".compiled-library",".library")
\# disabling prompts for storage version upgradesystem.prompt_answers["UnserializableDataError2"]=PromptResult.Cancelsystem.prompt_answers["LossOfDataWarning2"]=PromptResult.Noprint("searching libraries to install")repo=librarymanager.repositories[0]forlibdirinLIBDIRS:Â Â forextensioninEXTENSIONS:Â Â Â Â fordir,subdirs,filesinos.walk(libdir):Â Â Â Â Â Â forfilenameinfiles:Â Â Â Â Â Â Â Â iffilename.endswith(extension):Â Â Â Â Â Â Â Â Â Â fullpath=os.path.join(dir,filename)Â Â Â Â Â Â Â Â Â Â print("installing: ",fullpath)Â Â Â Â Â Â Â Â Â Â try:Â Â Â Â Â Â Â Â Â Â Â Â librarymanager.install_library(fullpath,repo,overwrite=True)Â Â Â Â Â Â Â Â Â Â exceptExceptionase:Â Â Â Â Â Â Â Â Â Â Â Â print("exception: ",e)Â Â Â Â Â Â Â Â print("script finished.")
Warning: I cleaned both scripts by removing some internals, and did not re-test them in their new shape, but they should still be useful for you to get the idea.
I hope that helps you a little...
Best regards,
Frank Jepsen
kk-electronic a/s
Regards,
Markus
Ok. That sounds like a reasonable workaround. Thank you.
// Frank
Regards,
Frank
Hi, Frank,
Thanks Markus. Those examples really helped.
