Hi, I have to switch the IDE to Codesys version 3.5.17. Unfortunately I have been in troubles with opening project saved in version 3.5.16 - there are missing Symbols, Visualization and Visualization Manager in Application. The 3.5.17 is trying to explain me during the project opening that I have to do "save as.." the project in older Codesys version using format 3.5.17 - but there isn't that option.
You open your project file in 3.5.SP17 and then you will get a pop-up for updating the environment. Then you set all to newest.
If still you are getting errors, then open your error tab and there you will get a option of download the missing libraries. Do it then problem will be fixed.
It is simple, if you are still facing the issues, share me your errors.
Last edit: TONY STARK 2021-08-04
Hi Tomas
It is easy to handle this stuff.
Hi Tony,
thank You for the answer. The issue was in corrupted installation of CODESYS 3.5.17.10 - after reinstallation everything starts working fine.
π
