fredashbolt - 2026-03-10
I am trying to generate a JSON payload populated with a value that updates for use with a telemetry system, the payload is to be published by MQTT.
I have established the MQTT client and can publish a working JSON payload but I can't get the payload to update as the value (iValue) changes. I am using a timer to trigger the .SetValue function periodically, but the JSON will only give the value as it is when it is first initialized using xFirst IF statement.
Any suggestions?
pJsonData : POINTER TO JSON.JSONData := factory.Create();
fb_JBuilder : JSON.JSONBuilder;
diRootIndex, diObject1Index : DINT;
iValue : INT := 10 ;
jsonArrayWriter : JSON.JSONByteArrayWriter;
wsJsonData : WSTRING(1000);
xFirst : BOOL := TRUE;
utf8JsonData : STRING(2000);
diTempVal : DINT ;
PublishTimer : TON ;
IF xFirst = TRUE THEN
fb_JBuilder ( pJsonData := pJsonData , diRootObj => diRootIndex ) ;
diObject1Index := fb_Jbuilder.SetKeyWithObject ( "Device" , diParentIndex := diRootIndex ) ;
diTempVal := fb_Jbuilder.SetKeyWithValue ( "Temp" , iValue , diParentIndex := diObject1Index ) ;
xFirst := FALSE ;
PublishTimer ( IN := PublishTimer.Q = 0 ,
PT := T#5S ) ;
IF PublishTimer.Q THEN
fb_JBuilder.SetValue ( iValue , diTempVal ) ;
jsonArrayWriter( xExecute := PublishTimer.Q ,
pwData := ADR(wsJsonData),
udiSize := SIZEOF(wsJsonData),
jsonData := pJsonData^,
xAsyncMode := FALSE ) ;
JSON.Stu.ConvertUTF16toUTF8(
ADR ( wsJsonData ) ,
ADR ( utf8JsonData ) ,
SIZEOF ( utf8JsonData ) ,
bStrictConversion := TRUE ) ;
