I am new to OPC and need some advice. I got the OPC running and when i check the tags with Matrikon Explorer all seems fine no bad connections . The problem is the next step How do I get the info from OPC to Ms Access and back. Don't have a lot of knowledge about OPC . Is there a tutorial or guide available .Or if possible can I go direct from Ms access to codesys.
It is possible in MS Access to add vbscript code. This script can call e.g. a dll or .ocx.
There is a freeware OPC client component available on the internet called "opc_da20_components.exe".
When you install this you can call it from e.g. an Access Form with the following code:
(PS, you can also use the SQL4Automation libraries to connect your PLC to any database supporting ODBC).
Option Compare Database
Option Explicit
'Declare all the variables
Dim groups As Variant
Dim group As Variant
Dim Items As Variant
Dim Item1 As Variant
Dim opcauto As Variant
Private Sub Form_Load()
Me.TimerInterval = 1000
'Get OPC Automation Reference
Set opcauto = CreateObject("OPC.Automation.1")
'Connect to the server
opcauto.Connect ("YourOPCServername.xxx")
'Plays with groups and items
Set groups = opcauto.OPCGroups
Set group = groups.Add("Device1.Group")
group.IsActive = True
Set Items = group.OPCItems
Set Item1 = Items.AddItem("Device1.Group1.Tag1", 1)
End Sub
Private Sub Form_Timer()
'Read Item1 and display in Label
Item1.Read (1)
Label0_v.Caption = Item1.value
Label0_q.Caption = Item1.Quality
Label0_t.Caption = Item1.TimeStamp
End Sub
Private Sub Form_Unload(Cancel As Integer)
opcauto.Disconnect
End Sub
Option Explicit
End Sub
Item1.Read (1)
End Sub
opcauto.Disconnect
End Sub
Thank you will give a go
