I am having the same issue. I am a bit worried, I was using CODESYS 64 3.5.15.30 and CODESYS Control for Raspberry PI 3.5.15.30. I decided to update Codesys and the Raspi Package and I am having the same issue. Were you able to solve it? I'm worried because this is a work project that was working fine and then this happens. Please help.
I forgot to mention, this is happening with CODESYS 64 3.5.17.0 and CODESYS Control for Raspberry PI 4.1.0.0. I cannot run my code because of this issue.
hello.
after installing the latest version of codesys when creating a new project it does not compile and throws this error
C0299: Failure to create a code generator. The required plug-in is not installed Build finished
I have reverted to the previous version
Windows Start Menu > CODESYS > CODESYS Installer > Change > Browse > type "Generator ARM" > Install these two generators.
Hi @i-campbell,
Thanks so much, that fixed it. Would I have to do that if I install Codesys in a new machine? Thank you.
