How to record timestamp in a variable?
open
2023-02-14
2023-02-20
  • open - 2023-02-14
    I am new to codesys programming,
    How to record timestamp and saved the value in a variable?
    I need to record start time and end time of a process.
    Warmest regards.
  • fraccaroli - 2023-02-14
    what device are you using? There could be manufacturer's libs that do it.
    As general advice I will use the classical way of embedded system: create a variable and count cycles (assuming that your process is in ciclic task).
    Another way could be to use the Task configuration > Monitor tab.
    Francesco
  • open - 2023-02-20
    Hi Francesco,
    Thank you for your reply,
    I used SysTimeRTC library to get the PLC time.
    I wrote a if function a boolean variable true then freeze the start time in a date_time variable.
    Warmest regards,
