Limit-switches in user-space
2012-04-02
2025-06-22
  • Anonymous - 2012-04-02
    Originally created by: Nicolai_Hanssing
    I am currently working with a PLC-Open implementation that does not support hardware limit-switches in the Target.
    Is there anyway that I can map/update the limit-switch structure in user application-space?
    Paramenter #1206 AXIS_REF.bHWLimitEnable must ofcourse be true, but where and how it the pointer-mapping and/or update for these inputs done?
    I need this on a modulo-configered axis, which is actually a linear axis, but needs modulo-positioning due to absolute position excceding 2^31 increments which is not handled correctly in PLC-Open Softmotion.
    Right now I have my own handling implemented, but I would like to also pass limit-switches to the Softmotion-library to have 'belt & suspenders' solution.
    Regards
    Nicolai Hanssing
    Soem investigation shows these FB might be relevant:
    SMC_HardwareEndSwitches(
    bLow:= ,
    bHigh:= ,
    Axis:= ,
    bOutOfArea=> );
    SMC_HardwareEndSwitches_Config(
    bLow:= ,
    bHigh:= ,
    Axis:= ,
    bOutOfArea=> );
    From the text-description it is not clear exactly how this could be used, but I suppose it would normally reside in the Drive-cycle Execute_Start-call handled by the driver-lib.
    But which to use, and how to use it in user-space?
    Nicolai Hanssing
