How to change bHiresMode
niallel
2024-03-11
2024-03-12
  • niallel - 2024-03-11
    I'm trying to get Scaling working on my axis. An increment produces 36.6mm of movement, so I want to put the units in application as 36.6.
    However the docs say that I need to change bHiresMode as it doesn't show me the option for Precision in the User Interface.
    I'm thinking that I need to change the precision so I can enter decimal places.
    How can I do this, or is my thinking wrong?
    Thanks,
  • Fless
    Fless - 2024-03-12
    you should see 2 input fields in the scaling tab of your linear axis:
    increments and units in application
    just set increments to 10 and
    units in application to 366
    • niallel - 2024-03-12
      Thank you so much for the reply.
      The motor is a rotary connected to a linear actuator. So would I set it up as in the attachment screenshot?
  • Fless
    Fless - 2024-03-12
    you need to set the increments to 10 (the screenshot shows 10000 hex = 65536).
    all the turn settings to 1.
    and the application units to 366.
    But usually you use the resolver resolution per motor turn.
    Insert the gear ratios (1:1 for no gear)
    and the last field you put the circumference of your drive wheel.
      That's brilliant, thanks so much for all your help.
