Create and write data in a file text (csv)
julien
2021-03-10
2021-03-10
  • julien - 2021-03-10
    Hello everybody,
    i try to write data in a file text without succes.
    I use the CAA_File library.
    First problem, I never get the position at the end of the file.
    I know the handling of the files is asynchronous, so I put a timeout between fileof and filwr to make sure the return from fileof.xDone and fileof.xEOF is done correctly.
    If xEOF is false, I increment the position by one and execute filsp (setPosition) and retest fileof (xExecute: = TRUE)
    However my pointer position index increases to values exceeding thousands when there are less than 10 characters.
    I have to write a file of three lines and twenty-one columns from an array of variables (nothing complicated there to loop).
    The loop work as:
    1 - getPosition
    2 - test if xEOF
    3 - If not xEOF then iPosition++, setPosition and back to test xEOF.
    4 - If xEOF then write the data[i] in the text file and back to getPosition for pprocess the data[i+1]
    5 - i and j = maxCounter then filcl
    I can't find the right way to do this with filgp, fileof, and filsp.
    Would you like to explain to me how and how fileof works?
    Thanks.
    Last edit: julien 2021-03-10
  • i-campbell
    i-campbell - 2021-03-10
    I do not know the answer to your problem. For me though, I think the CAA File is still very low level and difficult to get right. If you want to save yourself some hassle, use the CSV Utils SL library.
