Inline Monitoring not working
ahmedosama
2021-12-27
2021-12-28
  • ahmedosama - 2021-12-27
    Hello everybody,
    This is my first time using codesys. I searched for a thread about my issue but I couldn't find one ,so if there is a thread for my issue please let me know.
    my inline monitoring feature is not working during online mode.
    -I'm using Codesys V3.5 sp17 patch 1
    -I'm using Codesys Control Win V3 x64
    -the inline monitoring feature is enabled in the project option in the : text editor & monitoring tab
    -the inline monitoring is enabled also in the advanced menu
    I hope I've given you enough info and please let me know if you need more info and I will provide it to you.
    Note: the Codesys is running on a VM that is not connected to the Internet.
    Thanks in advance. I really appreciate any guidance in this matter.
  • ahmedosama - 2021-12-28
    update:- I've tested the same project on another machine and the inline monitoring works fine, so it's probably not the project option
    -I've installed the codesys on another machine ( different from the one I tested the project on) and created a new project and the monitoring works fine ,so It' probably not a codesys isuue either.
    I believe it's the Vm I'm working with ( I tried disabling the firewall but that didn't work).If anyone has a guess as to what could be the issue in the Vm that causes the inline monitoring not to work
