Refferencing MCP23s17 inputs/outputs in GVL
mbruck
2015-09-09
2015-09-10
  • mbruck - 2015-09-09
    I want to create and map custom boolean variable list to point to MCP23S17 input/output pins. Only what I figure out is this.
    I have created global variable list like this:
    VAR_GLOBAL
       in1:BOOL (MCP23S17.byInputsA.0);
       out1:BOOL (MCP23S17.byOutputsA.0);
    Then in POU's ST code this:
    out1:=in1
    Is this syntax ok? What is the "proper" way to create variable map list to mpc's pins ?
    Thank you !
  • fixstuff555 - 2015-09-10
    If you want something that works, it may not be exactly what you want but I would just instantiate the device in the globals, like so:
    MCP1: MCP23S17;
    in1: BOOL;
    out1: BOOL;
    and then use in the ST code of the POU like this:
    in1:=MCP1.byInputsA.0;
    out1 := in1;
    MCP1.byOutputsA.0 := out1:
    or this:
    MCP1.byOutputsA.0 := MCP1.byInputsA.0;
    Not sure if you can define like you want to in the globals somehow, but I could be wrong..
  • mbruck - 2015-09-10
    My intention was to declare all inputs and outputs boolean variables in one (global) place, so I can use it on several POU's.
    I know I can use this code MCP1.byOutputsA.0 := MCP1.byInputsA.0; but i'd like to use more meaningful input/output names.
    However I still don't know is this
    VAR_GLOBAL
    correct or not ?
