I seem to be getting errors from the following script:
sudo /root/rts_set_baud.sh
#!/bin/sh
BITRATE=expr $2 \\* 1000
ifconfig $1 down
echo ip link set $1 type can bitrate $BITRATE
ifconfig $1 up
I am looking for a tutorial on how to configure a Pi3 to use Canbus through an MCP2515. Is there any available?
anyone?
Using the candump command, I am able to see the network Packets.
However, I am still getting a bus failure in codesys
#!/bin/sh
BITRATE=
expr $2 \\* 1000ifconfig $1 down
ifconfig $1 up
Edwin? Can you help?
I'm having the same problem ... Do you know more about that ?
Best Regards
Create rts_set_baud.sh file in /root/ and chmod it to 777.
