CoDeSys loses connection with runtime
2017-03-16
2017-03-25
  • Anonymous - 2017-03-16
    Originally created by: Viacheslav Mezentsev
    RaspberryPi B, CoDeSys 3.5.10.x
    Example project.
    You can try keyboard for example (you need to change path, see: ls /dev/input/by-path on your device):
    fileName: string := '/dev/input/by-path/platform-3f980000.usb-usb-0:1.3:1.0-event-kbd';
    Steps to reproduce the problem:
    1. Login and download the project.
    2. Run project.
    3. Logout.
    4. Build/Clean.
    5. Login ... CoDeSys loses connection with runtime.
    Worked with all events and not only with SysFileAsync library (CAA File with the same result).
    So the question: Why CoDeSys 3.5.10.x loses connection in this case?
    How to restore connection:
    sudo /etc/init.d/codesyscontrol stop
    sudo rm -R /root/PlcLogic
    sudo /etc/init.d/codesyscontrol start
  • Anonymous - 2017-03-21
    Video: https://youtu.be/bGNL8n5qV64 m
    A temporary solution to the problem. You need to create a global Boolean flag. Use it to free the file handle manually without leaving debugging (assign a hotkey, for example). When the handle is released, you can exit debugging.
    This means that the runtime cannot properly close the handle of such file.
  • Anonymous - 2017-03-25
    Undocumented solution (rus).
    There I show a trick which will help to solve this problem, but the runtime developers should not relax and must correct the connection loss bug. I need this not for raspberry pi. This is just an example which works not only for raspberry but for other linux platforms too.
