Codesys Runtime Devie Password
oproulx
2022-11-17
2025-02-11
  • oproulx - 2022-11-17
    I installed CODESYS Control RTE SL 3.5.18.30 on a Siemens IPC to do some tests and when I try to Login using the IP address of the IPC, it ask me a user name and password for the Device.
    I don't remember setting that up when I installed the runtime (unless I miss it) and there is no user in my project either.
    I tried some classic administrator password but it's not working out.
    Any idea what that user could be or how to login/download without it.
  • oproulx - 2022-11-18
    To follow up and close this post, if anybody get that similar problem.
    Simply go in the root folder of the PLC Runtime on the Device and delete the CSV files.
  • Stefan - 2025-02-11
    Where do i find those files for 3.5.20? They seem to be relocated ...
  • TimvH
    TimvH - 2025-02-11
    This has been moved because of security reasons.
    But it depends on how you start CODESYS where the project files are located (at least for Control Win from SP20).
    1)
    If you start it through the sys tray icon, you start it as a service and the files will be located in: C:\Windows*System32\config\systemprofile\AppData\Roaming\CODESYS...
    (or C:\Windows*
    SysWOW64**\config...)
    2)
    If you start it as a user, e.g. with a shortcut to the runtime, you can find it in:
    C:\Users\<your user="" name="">\AppData\Roaming\CODESYS...</your>
