After a windows update I am unable to access the webvisualizations via HTTPS. HTTP still works as expected. When launchung the Codesys Control (Win V3 x64) I get the errors below.
2021-02-17T03:11:58.732Z: Cmp=CmpWebServer, Class=1, Error=0, Info=0, pszInfo= **********
2021-02-17T03:11:58.732Z: Cmp=CmpWebServer, Class=1, Error=0, Info=0, pszInfo= Web Server
2021-02-17T03:11:58.732Z: Cmp=CmpWebServer, Class=1, Error=0, Info=0, pszInfo= Root directory : $PlcLogic$/$visu$
2021-02-17T03:11:58.732Z: Cmp=CmpWebServer, Class=1, Error=0, Info=0, pszInfo= Host : sdsadasd
2021-02-17T03:11:58.732Z: Cmp=CmpWebServer, Class=1, Error=0, Info=0, pszInfo= HTTP port : 8080
2021-02-17T03:11:58.732Z: Cmp=CmpWebServer, Class=1, Error=0, Info=0, pszInfo= HTTPS port : 443
2021-02-17T03:11:58.732Z: Cmp=CmpWebServer, Class=1, Error=0, Info=0, pszInfo= Connection type : HTTP, HTTPS
2021-02-17T03:11:58.732Z: Cmp=CmpWebServer, Class=1, Error=0, Info=0, pszInfo= ************
2021-02-17T03:11:58.732Z: Cmp=CmpOpenSSL, Class=1, Error=0, Info=0, pszInfo= TlsCreateContext: The given namespace 'WebServer' was not found in config file.
2021-02-17T03:11:58.732Z: Cmp=CmpWebServer, Class=1, Error=0, Info=0, pszInfo= The needed certificate is not available for HTTPS.
2021-02-17T03:11:58.732Z: Cmp=CmpWebServer, Class=1, Error=0, Info=0, pszInfo= HTTPS is not working with your configuration. See previous log entries for details!
2021-02-17T03:14:28.972Z: Cmp=CmpWebServer, Class=1, Error=404, Info=0, pszInfo= File $PlcLogic$/$visu$/favicon.ico not found on this server
There appears to be no configuration for HTTPS in the CODESYSControl.cfg file
[CmpWebServer]
;The handling of startup/shutdown of the webserver:
;0->automatically start, shutdown only on shutdown of the runtime;1->automatically start, could be shutdown on demand
;2(default)->start/shutdown on demand;3->start on demand, shutdown only on shutdown of the runtime
;StartupType=2
;The TCP port the webserver listens on
;WebServerPortNr=8080
;LocalAddress=127.0.0.1
;LocalAdapterName=LAN-Connection
;LocalAdapterNameUnicode=L\00A\00N\00-\00C\00o\00n\00n\00e\00c\00t\00i\00o\00n\00
What changes need to be made to the config file to remedy this?
[CmpWebServer]
;StartupType=2
