Runtime : CODESYS Control for Linux ARM64 SL 4.5.0.0 (CODESYS Control based on CODESYS SDK 3.5.18.20)
I am running the runtime from a Docker container. I have an application running with the demo licence. It is running a boot project when the Docker container is restarted. All good there, but I need to ensure that a licence is present in future and that it won't be lost when the container exits.
The main issue is trying to add a licence. Using a Dongle is not an option. My understanding is that there should be no difference between using a dongle and a soft container, but the attached image does not indicate this. I had chosen the 'Soft Container' option when using the 'License Manager', but I was still prompted "There is no dongle attached to the device". Is there a configuration change required to correct this?
Some further information. I can try start a codemeter service but it fails, yet CodeMeterLin binary starts. The codemeter-webadmin service does not fail, and CmWebAdmin binary will run. Accessing the web admin interface via browser is denied though. This means I have limited options to change any codemeter-lite configuration.
Hopefully I can get some feedback on this issue, I can't seem to find any resource in the online help that helps with this sort of licence issue.
Thank you.
