Hello. I updated Windows 10 on several PCs where I was using CODESYS with no problem.
Now I cannot save projects on this PC. Tried to reinstall the CODESYS package and have compatibility package installation.
Will be grateful for comments and advise.
spfollen, the only work around I could find was to install the 0x86 (32-bit) version, even though the PC is a 64-bit system. The 32-bit version solves the problem. I found this happened when I installed a completely unrelated software on the same PC, the engineering tool from a different PLC maker. I hope this is a solution for you too.
π
1
more posts ...
Also Have this installation problem when attempting to reinstall package
I have this problem as well
