Codesys Input Detector
2024-02-15
2024-02-16
  • durstloescher - 2024-02-15
    Good morning,
    I am currently working on implementing a display dimmer. I want the display to dim after X minutes. This works so far.
    The implementation is done via the Linux subsystem, to which a command is sent to dim the display.
    However, my problem is resetting the timer when input is received.
    I want the dimming timer to be reset with each click/touch. Unfortunately, I can't find a suitable solution for this.
    Are there any ways to do this?
    Codesys v3.5 SP19 Patch 2
  • durstloescher - 2024-02-16
    Perfect, works after a bit Try & Error, Thank you!
