I'm on codesys SP17.30 on raspberry pi 4.4.
On webvisu, when I want to log user, I have problem with windows to write login and password. When I click OK, windows don't disappear and un ghost square appear and block all fonction on webvisu. I have to relaod webpage.
Somebody could help me ?
There is a workaround to not use this automatic wondows to set login and password ? With field text element ?
The problem isn't with usermanager or with windows to login The problem is when text fiel is set for password
Drag a test field element from the ToolBox view (Common controls) to the visualization.
Click the Input configuration node in the Properties view.
Click auf Configure in the property Input configuration β£ OnMouseClick
Select Write variable and set Password field : Invisible text input. *** is displayed instead of the input text.
When you write text on text field: problem appear
I recently faced the same problem.
Seems like it will be fixed in Visualization plugin 4.2.0.0 (VIS-1152). At least I hope this is the same issue.
I also can say that this problem was not in 3.5.16.30 (I watched her in 3.5.17.30).
Last edit: kislov 2022-03-04
Thanks for your help.
Best regards.
Last edit: galexis 2022-03-04
See https://forge.codesys.com/forge/talk/Visualization/thread/59eb8212c7/
Is it possible to update this library independly of codesys 3.5.17.30 ? Where I can download it ?
I haven't got update on codesys installer.... How to update VIS to 4.2?
VIS 4.2 is currently in development
The new version of Visualization solve problem ! π
