Alarm manager project v3.5.12.8
2021-03-12
2021-03-13
  • nijmegen024 - 2021-03-12
    Now im on a project with sensor s and variabele air flow.
    When a sensor is not oke OR the emergency button is pushed there must be an alarm visible on the HMI.
    Can you help me with An example project alarm manager version 3.5.12.8
  • hermsen
    hermsen - 2021-03-12
    For loads of examples, including examples on how to program and use the alarmlist, see Home, select projects, then select codesys examples. Have fun and good luck ;-)
    Hi, h-hermsen,
    I thank very much for your answer but my problem is now i have version V3.5 SP12 and the exapmles are only compatible with SP14
    Do you have ideas for examples with compatibility with SP12?
    Last edit: nijmegen024 2021-03-12
  • hermsen
    hermsen - 2021-03-13
    What I would do: just ignore the compatibility warning.
    Download the example, open it and downgrade the libraries so it will compile in your IDE.
    Then run the examples and study them.
    I bet it will work just fine.
