CODESYS IDE unable to show Visu when online over VPN
2021-06-14
2021-06-30
  • mandeepahujaifm - 2021-06-14
    Hello all,
    [SP 16 Patch 4]
    We have a VPN connection that we use to log in with the controller. The problem is CODESYS IDE does not show the visu when online with the controller. WebVisu works ok, Target Visu works OK, it's within CODESYS IDE that doesn't show the display.
    The logs from the controller are attached.
    The error is something like this
    Visu_PRG: Successfully Removed Client with IEC-ID 3
    Visu_PRG: Creating Successful for Extern-ID: 4748 Returned IEC-ID: 3
    Any help is appreciated
  • m.prestel - 2021-06-30
    Client seems to time out, even though it is not clear if it is the IDE client
    Best regards,
    Marcel
