I'm trying to set up either a Trend or a Trace to visually graph some data.
The Trend is nice as you can adjust your time sample for the data however it drastically slows down the PLC when the visualization the trend is used.
The Trace function works well however it seems very limited on the functionality, I'm unable to change the axis colors. If possible can you change the x axis from the start time of the HMI to the current UTC time? If I can perform those changes the Trace function would work better for me.
